It is currently Sat Jul 26, 2025 7:05 am
 Post subject: Arne Schlunsen rebuild
PostPosted: Thu Feb 07, 2008 4:31 pm
Hey all! I,m looking for a luthier in the central oklahoma area who would be interested in rebuilding a 1961 Schlunsen. Heres some photosImageImageImageImageImage Thanks, Jim
PostPosted: Thu Feb 07, 2008 5:05 pm
i'm gonna be of no help here, but does it have steel strings on it? It looks like a classical with steel strings, and that's what would happen to a lightly built one.
PostPosted: Thu Feb 07, 2008 5:40 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I might be wrong waddyt but I believe it just has a set of ball end classical strings.
PostPosted: Thu Feb 07, 2008 5:41 pm
Schlunsen was a well known Danish maker of classical guitars. I played one a couple of his guitars in a shop Copenhagen last year, and one looked similar to yours, I think the rosette was was exacly the same. It was a nice sounding guitar... The shop owner, who had known the guitar maker, told me the famous story of when Segovia had visited Schlunsen's shop and played one of his guitars. He liked the guitar and expected the luthier to offer it as a gift, but Schlunsen refused and told he had to pay like everyone else... [:Y:]
Anyways, your guitar is in bad shape and those steel strings (if that is what they are) didn't help. Does it have BRW back and sides? It will need some pretty extensive and time consuming repairs, and I don't know if the value of the restored instrument will warrant the cost. Unfortunately I am also unable to give you any info about repair people in OK...
Not much help, are we?!
PostPosted: Thu Feb 07, 2008 5:48 pm
Man that is a light one! that looks like less than 2mm's is that right for a classical?
PostPosted: Thu Feb 07, 2008 5:51 pm
Yes it is. Light and right, that is. Mine is in the 1.8 - 1.9mm at the edge. Torres' SE 107 was 1.4mm at the edges.
PostPosted: Fri Feb 08, 2008 1:39 am
A steel string would go right through that! But I'm not sure those are steel are they?
PostPosted: Fri Feb 08, 2008 3:31 am
I'm certainly no expert but...
That's the kind of damage I'd expect to see if a classical guitar were strung up with steel strings and then left in a hot car for a day or two. It all seems to be glue joint failures and too much string tension. Or normal string tension and left in a hot car for a day or two.
Can you tell us how the damage occurred?
And, can our repair experts give a critique on what might have caused the failure of this guitar? Failures like this are something all us hobbyist builders can all learn from.
Not that I'm going to be able to help much in a repair sense, seeing as I'm in Australia. But I'd love to get my hands on a good guitar in that condition for repair practice if nothing else.
PostPosted: Fri Feb 08, 2008 4:41 am
Can we forget this steel string stuff, they are ball end classicals. Looks like the damage that could happen if it was leant against the wall and something knocked into it, mechanical folding. Doesn't look like a Spanish heel so that should make the repair easier.
PostPosted: Fri Feb 08, 2008 9:32 am
Like Colin said. The bridge looks firmly attached to the top, so it looks like a fall or a blow rather than steel strings. The bridge would have come off way before the neck block/neck joint…
Looking at the quality of the tonewoods it seems the guitar is worthy of restoring.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Apr 23, 2008 5:58 pm
Jim
What a disaster :o I can make the repairs but I am in West Texas and It would be about 8 months before I could get to it.
PostPosted: Wed Apr 23, 2008 6:35 pm
Does Johhny Walker do repairs? I kind of doubt it, but I bet he could reccomend someone there in Oklahoma. Walker is a top-notch classical builder in Bartlesville. You can e-mail him on his website.
Wayne
PostPosted: Fri Apr 25, 2008 12:44 pm
I have repaired several guitars with this exact same damage. It is caused by overheating. The glue fails on the upper transverse brace which starts a landslide of other damage including the top cracks along the fretboard, the neck tenon pulling loose, and the caving in of the sides at the head block. That last last symptom is the dead giveaway, along with slippage of the rosette.
I start the repair by clamping the body face up to my workbench and then using a heat gun to soften up the internal head block area while slowly clamping the neck down. This will pull most of the parts back into position. Then let it cool down, and follow up with regluing the upper transverse brace to the top. Additional reinforcement of the top cracks are usually necessary.
PostPosted: Wed May 07, 2008 4:59 pm
That's interesting, Barry. What type of glue was used on the parts that came unglued on the guitars you repaired?
Last bumped by Anonymous on Wed May 07, 2008 4:59 pm.
